I use the tool menu with the following command :
fromelf -s -o T:\TGIP\fichiers_uVision3\TGIP_BM.sym T:\TGIP\fichiers_uVision3\ObjectFiles\TGIP_BM.axf
But I want to change the output file name TGIP_BM.sym to GIP.D.1.56.sym
this name coming from a constant defined in my code
const CHAR cGIPVersion[] = "VER=GIP.D.1.56";
How can I write a macro called after compiling which could get the variable string ?
When I use eval cGIPVersion in the Command tab in replies with the address : cGIPVersion 0x000344CC
but not with the content....
make "VER=GIP.D.1.56" part of the build .bat and include it as an external value to the linker to get it inside the code. Then use it for the fromelf command string.
