is it possible to print some debug information to the debug window (build output window)?
Like printf() for the uart interface...
best regards Bernd
The Debug Output window is not the same as the Build Output window!
So which one do you actually mean?
There is, of course, also the Serial Output window(s) - which you can use when debugging in the Simulator...
For details of commands available in Debug mode, see: http://www.keil.com/support/man/docs/uv4/uv4_debug_commands.htm
For documentation on Debug Functions, see: http://www.keil.com/support/man/docs/uv4/uv4_debug_functions.htm
I don't think that Keil compilers support #pragma message or #pragma warn or suchlike - but you'll have to check the appropriate manuals for that...
