mktime behaviour
I use mktime to convert date and time into a time_t value and I see a behavior, which I didn't expect.
When calling mktime with 29.02.2010, I would expect the function to return -1, but it returns a time_t value representing the 01.03.2010.
Is that the normal behavior?
  • mktime() is defined accept just about anything that fits into the input fields. To quote the standard on it:
    and the original values of the
    other components are not restricted to the ranges indicated above
    mktime normalizes all fields of the input struct tm to their respective validity ranges. That's the majority of its job. It's even allowed to use mktime() on 9999-99-99T99:99:99, and get a useful (to some extent) result.
    The return value of -1 only applies if the conversion from struct tm to time_t fails. That follows from this clause in the standard:
    The mktime function returns the specified calendar time encoded as a value of type
    time_t. If the calendar time cannot be represented, the function returns the value
    (time_t)(-1).
    if you follow the use of the term "calendar time" closely.
    (time_t)(-1).
