Problem with the SSP1 - LPC1768
Please allow me to ask the simple questions.
I want to implement SPI communications between LPC1768 and M25PE16 (Serial Paged Flash Memory).
When I send 0x9F (ask for chip ID) to the M25PE16, I get only one time interrupt. I expected 8 bytes response.
When I send 0x9F again I receive next byte response. Could you please take a look at my code and give me a clue what I may miss?
Sorry for my English.
Best Regards.
void spi_init (void) {
   /* Initialize and enable the SSP Interface module. */
  LPC_SC->PCONP        |= (1 << 10);              /* Enable power to SSPI1 block  */
  LPC_SC->PCLKSEL0 &= ~(3<<20);
  LPC_SC->PCLKSEL0 |=  (1<<20);
  LPC_SSP1->CPSR = 4;
  LPC_SSP1->IMSC = 0x0006;
  LPC_SSP1->CR0  = 0x0007;                        /* 8Bit, CPOL=0, CPHA=0         */
  LPC_SSP1->CR1  = 0x0002;                        /* SSP0 enable, master          */
  NVIC_EnableIRQ(SSP1_IRQn);
void SSP1_IRQHandler (void)      //odbior danych z pamieci
        wskSSP1RIS = LPC_SSP1->RIS;
if((wskSSP1RIS==0x02)||(wskSSP1RIS==0x08)||(wskSSP1RIS==0x0A)) //rcv znak { while(LPC_SSP1->SR & 0x04) memData[countMem++] = LPC_SSP1->DR; } if(countMem == 8) { countMem = 0; spi_ss(1); //cs high } LPC_SSP1->ICR = 3; }
  • With the section of code posted and not having used this particular chip, I would say this sounds correct.
    You need to write out dummy byte, to initiate the other device (slave) to send, if you are expecting 8 bytes then you need to write out 8 bytes to cause the other device to clock out its 8 data bytes.
