Dear all, my usb msc+cdc composite project work well in winxp ;but in win7,my cdc vcom could not recieve&send data;my cdc inf file is mchp_MSD_CDC.inf,is ok in win7,because cdc project also work well in win7.
when (win7) reinstall&uninstall vcom deriver in devicelist,pc requrie a long time.
my platform is lpc2368,modify mcb2300 demo code
Really?
Microchip INF files for CDC don't follow these MS guideline of INF, even on the latest (v2.7) version of MCHPFSUSB stack (v2010-04-28).
1) Don't write LayoutFile on [Version] section. 2) Don't specify usbser.sys directly for CopyFiles Instead, include mdmcpq.inf AND refer to FakeModemCopyFileSection
I've pointed out it on this topic of Microchip forum. " href= "http://msdn.microsoft.com/en-us/library/ff547502">msdn.microsoft.com/.../ff547502(VS.85).aspx LayoutFile Note This entry is not supported in Windows Vista and later versions of Windows.
2) How to use or to reference the Usbser.sys driver from universal serial bus (USB) modem .inf files support.microsoft.com/.../837637
Tsuneo
I use win7-32bit mode
thank you, Tsuneo Chinzei! I use mchp_MSD_CDC.inf(v2.7) file in win7,cdc project is really ok,but msc+cdc compostie project is bad.
Tsuneo, Did you test cdc+msc composite device in win7?
when i plug my cdc+msc on win7,and update cdc deriver in devicelist,select the inf file,install.....pc is always in installing stae. my cdc+msc composite problem in win7,maybe is nothing with inf file; Tsuneo, did you test cdc+msc composite device in win7?
thank you very much!
In this weekend, at last, I got enough spare time to test this issue ;-)
Made a MSC + (IAD) CDC composite device on Keil MCB2300 board. Just merged Keil Examples (USBMem and USBCDC) together in quick and dirty way.
Here is the test code link www.8052.com/.../MCB2300_MSC_CDC.zip
And tested on these Windows versions
Result
Windows XP (x86) SP3 - success Windows XP (x64) SP2 - installation success, but driver failed to start in Code 10 Because of old drivers - usbccgp.sys 5.2.3790.3959, Feb 18, 2007 - usbser.sys 5.2.3790.1830, March 24, 2005
Vista (x86) SP2 - success Vista (x64) SP2 - success
Windows 7 (x86) - success Windows 7 (x64) - success
Here is a revised INF file for this test This single INF works for both of x86/x64 on all Windows version (XP, Vista and 7) The original USBCDC example is also supported.
Enjoy!
Tsuneo mcb2300-vcom.inf (Revised)
; ; Keil - An ARM Company Communication Device Class driver installation file ; (C)2007-2008 Copyright ; [Version] Signature="$Windows NT$" Class=Ports ClassGuid={4D36E978-E325-11CE-BFC1-08002BE10318} Provider=%Keil% ;;; LayoutFile=layout.inf ;; not supported in Vista and later DriverVer =04/14/2008, 5.1.2600.5512 ; CatalogFile=mcb2300-vcom.cat [Manufacturer] %Keil%=DeviceList,ntamd64 ;------------------------------------------------------------------------------ ; Device list ;------------------------------------------------------------------------------ [DeviceList] %DESCRIPTION%=MCB2300USB, USB¥VID_c251&PID_1705 %COMPOSITE% =MCB2300USB, USB¥VID_FF28&PID_0001&MI_01 [DeviceList.ntamd64] %DESCRIPTION%=MCB2300USB, USB¥VID_c251&PID_1705 %COMPOSITE% =MCB2300USB, USB¥VID_FF28&PID_0001&MI_01 ;------------------------------------------------------------------------------ ; Installation ;------------------------------------------------------------------------------ [SourceDisksNames] ;;; this blank section satisfies chkinf [SourceDisksFiles] ;;; this blank section satisfies chkinf [DestinationDirs] FakeModemCopyFileSection=12 DefaultDestDir = 12 [MCB2300USB] include=mdmcpq.inf CopyFiles=FakeModemCopyFileSection AddReg=MCB2300USB.AddReg [MCB2300USB.AddReg] HKR,,DevLoader,,*ntkern HKR,,NTMPDriver,,usbser.sys HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider" [MCB2300USB.Services] AddService=usbser, 0x00000002, DriverService [DriverService] DisplayName=%DRIVER.SVC% ServiceType=1 StartType=3 ErrorControl=1 ServiceBinary=%12%¥usbser.sys ;------------------------------------------------------------------------------ ; String Definitions ;------------------------------------------------------------------------------ [Strings] Keil = "Keil - An ARM Company" DRIVER.SVC = "MCB2300 USB VCom Driver" DESCRIPTION= "MCB2300 USB VCom Port" COMPOSITE = "MCB2300 MSC-CDC COM Port"
thank you,Tsuneo. I wil test it. thank you,again.
