I am trying to generate a log file by invoking the function "fopen()" in keil for samsung S3FS92G target though i m getting the result in serial window but finally needs to log in txt or xml file. Even though I am not getting any compilation error (like fopen() missing) but the log file is not created at the expected system path. any help on generating a txt file using fopen
DO you mean that no file is created at all, or that it's created in an "unexpected" location?
What return value do you get from fopen?
http://www.keil.com/support/man/docs/rlarm/rlarm_fopen.htm
no file is getting created at all at any location, Its returning NULL value if((fp=fopen("record.txt","w"))==NULL) { printf("cannot open file"); exit(1); }
this part is just printing cannot open file on serial window
Note: i dont have keil FlashFS library
the ARM Std. C Library provide STDIO functions. You need to add a proper target-dependent low-level implementation! Semihosting is not supported in MDK-ARM so it must be switched off: http://www.keil.com/support/man/docs/armlib/armlib_ciheeaja.htm
The low-level stub functions from the ARM Std. Library are explained here: http://www.keil.com/support/man/docs/armlib/armlib_cihefhge.htm
Furthermore, this will not work if you have MircoLib enabled in uVision Options for Target -> Use MicroLib!
Regards, Alex
Anyway, you need some Middle-Ware which provide low-level file system access like to SD-Cards. Take a look to RL-ARMs FlashFS here http://www.keil.com/rl-arm/rl-flash.asp
BR, Alex
