I had tried to define a task like an extern so I could split my task in several files, but it doesnt works I dont know if I can define a task like external.
for exemple:
extern __task void tick_timer (void);
gives me error.
when I try this with others normal functions it works...so its not a problem of files or a thing like that
Gabriel
OK, what do you want to achieve actually? why would you want this? why not define your task, and let it call externally defined functions instead?
When having multiple tasks in different files, I just have a line:
void my_task(void) __task;
So of course you have have your tasks in different files. But from your text, you want to split a single task and have the code in several files. No function can have the code split into multiple files. The way to reduce the amount of code in a function is to subdivide the code and move to new functions.
Ok it was a misunderstanding I wanted to put several tasks in several files so its not a task in many pieces.... Its a good Idea to make calling to external fonctions but I wanted to know if I can make that directly, so thanks for the answer.....
I think I'm going to make calls to external functions
This builds just fine: main.c
#include <RTL.h> extern __task void task2 (void); OS_TID id2; __task void task1 (void) { id2 = os_tsk_create (task2, 1); for (;;) { os_evt_set (0x0004, id2); os_dly_wait (5); } } int main (void) { os_sys_init (task1); }
external.c
#include <RTL.h> __task void task2 (void) { for (;;) { os_evt_wait_or (0x0004, 0xffff); } }
Thanks I can see my error now.. I've had a preprocesor symbol "RTX_KERNEL" not defined so It was for that that it wasn't working...
#ifdef RTX_KERNEL
/* Forward references */ __task void init (void); __task void tick_timer (void); __task void tache_display(void); __task void tache_spi (void); __task void send_data (void); __task void send_data2 (void); __task void send_data3 (void); extern __task void flash_table (void); #endif
You can use uVision internal RTX switch instead of your own:
#ifdef __RTX // Options for Target - Operating system - RTX Kernel #else // Options for Target - Operating system - None #endif
