I had tried to define a task like an extern so I could split my task in several files, but it doesnt works I dont know if I can define a task like external.
for exemple:
extern __task void tick_timer (void);
gives me error.
when I try this with others normal functions it works...so its not a problem of files or a thing like that
Gabriel
OK, what do you want to achieve actually? why would you want this? why not define your task, and let it call externally defined functions instead?
When having multiple tasks in different files, I just have a line:
void my_task(void) __task;
So of course you have have your tasks in different files. But from your text, you want to split a single task and have the code in several files. No function can have the code split into multiple files. The way to reduce the amount of code in a function is to subdivide the code and move to new functions.
