"Wear Leveling" strategies in RL FlashFS ?
I want to implement the RL FlashFS in my design.
Many Flash ICs available ensure only 100.000 write cycles. Based on the idea of a Filesystem the amount of write cycles to a File Allocation Table can possibly exceed the amount of ensured write cycles, thus making wear leveling strategies mandatory.
- Does Keil RL-FLashFS support wear leveling ?
- What kind of strategies are supported ?
best regards, Andre
  • Andre,
    I believe the FAT file system is only used for memory cards like SDCARDs. Kiel use a propriety system for flash memory.
    However, I use SDCARD cards and from what I can Google it looks like SDCARDs incorporate wear levelling circuitry. Wackypedia has a little note on this in the following article
    en.wikipedia.org/.../Flash_memory
    I have also found confirmation of this within a SanDisk SDCARD datasheet which I could send you if your really interested.
    Stuart
  • Andre,
    Stuart
