Problem: Suppose there is uart tx code working on one simulator and a uart rx code working on the other simulator (on the same PC). So the two simulators should work such that the output one should be given as input to the other .
I don't know where to start.
First of all is it possible?
Does Keil RealView Development Suite Evaluation support this?
