Using a TMS470R1B1M board designed by myself, Non RTX program runs fine within and without flash, but when added RTX,os_dly_wait() and os_itv_wait() refuse to run in flash mode while they work sucessfully in debug mode. The flash.ini and flash_debug.ini are the same with samples provided by MDK, please give me an answer source codes follows:
/**********************************************************************************************************************/ /**********************************************************************************************************************/ #include "includes.h" DEVICE_CLKS *pDeviceClks; char strSciBuf[256]; OS_TID tidTime; OS_TID tidClock; OS_TID tidLed; OS_TID tidAdc; OS_TID tidSci; struct time_s { unsigned char h; unsigned char m; unsigned char s; } current_time; regSPI_t *pspi; ADS1278_APP pAdc; s32 AdcBuf[8]; u8 AdcBytes[24]; double AdcValue[8]; /* HET RAM start (dependant on MFBAHR4 value in TMS470R1B1M.s) */ #define HET_RAM 0x40000000 volatile HETPROGRAM0_UN e_HETPROGRAM0_UN __at(HET_RAM); //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // void delay(s32 lps) { vs32 i; for(i=0;i<lps;i++); } //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// //This function copies 32-bit values to destination from source addresses of size also given as parameter void memcopy32 (unsigned int *dest, unsigned int *src, unsigned int size) { size >>= 2; while (size--) *dest++ = *src++; } //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // __task void TaskTime (void) { for (;;) { os_dly_wait (100); /* wait for 100 clock ticks = 1 s */ if (current_time.s++ > (60-2)) { current_time.s = 0; if (current_time.m++ > (60-2)) { current_time.m = 0; if (current_time.h++ > (24-2)) { current_time.h = 0; } } } } } //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // __task void TaskLed (void) { static int m=0; GIO_OutEnBits(LED_GIO,LED_PIN,true); os_itv_set(50); for (;;) { if(++m%2==0){ sprintf(strSciBuf,"\r\nledon = %d\r\n",m); GIO_ClrBits(LED_GIO,LED_PIN); }else{ sprintf(strSciBuf,"\r\nledoff = %d\r\n",m); GIO_SetBits(LED_GIO,LED_PIN); } os_itv_wait(); } } //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // __task void TaskAdc (void) { s32 i; CLK_SetClkOut(CLKSR_ICLK); pDeviceClks = CLK_GetClocks(CRYSTAL_FREQ); //8Mhz SPI_SetClk(pSpiA,pDeviceClks->IClk,pDeviceClks->IClk/1000000L); SPI_OpenMaster(pSpiA,8,0,1); ADS1278_Init(&pAdc); pAdc.Open(1234); pAdc.Conv(0);delay(1000); pAdc.Conv(1); for (;;) { pAdc.Read(AdcBuf,4); for(i=0;i<4;i++){ AdcValue[i]=(double)AdcBuf[i]*2.500/(double)S32_MAX; } sprintf((char *)strSciBuf, "ASC%+06.3f,%+06.3f,%+06.3f,%+06.3f\r\n",AdcValue[0],AdcValue[1],AdcValue[2],AdcValue[3]); } } //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // __task void TaskSci(void) { int len; pDeviceClks = CLK_GetClocks(CRYSTAL_FREQ); //8Mhz SCI2_Open(pDeviceClks->IClk,9600); SCI2_SetSciClk(true); EchoInfo(); for(;;){ len = strlen((char *)strSciBuf); if(len>0){ SCI2_SendBytes((u8 *)strSciBuf,len); strSciBuf[0]=0; os_dly_wait(1); } } } //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // __task void TaskInit (void) { current_time.h = 0; /* Initialize current time to 0 */ current_time.m = 0; current_time.s = 0; GIO_OutEnBits(USB_ON_GIO,USB_ON_PIN | (1<<0),true); GIO_SetBits(USB_ON_GIO,USB_ON_PIN); pHET->HETGCR = 0x00010002; /* Clock master + ignore suspend */ /* Copy HET program from code memory to HET RAM */ memcopy32 ((unsigned int *) &e_HETPROGRAM0_UN, (unsigned int *) HET_INIT0_PST, sizeof(HET_INIT0_PST)); pHET->HETDCLR = 0x000000FF; /* Clear HET0..7 */ pHET->HETDIR = 0x000000FF; /* Setup HET0..7 as outputs */ pHET->HETPRY |= (1 << 1); /* Interrupt priority for HET1 */ pHET->HETPFR = 0x0000052B; /* Set prescale factor */ pSM->REQMASK |= (1 << 7); /* Enable HET interrupt 1 */ pHET->HETGCR |= 0x00000001; /* Start HET */ tidSci = os_tsk_create (TaskSci, 1); tidLed = os_tsk_create (TaskLed, 1); tidTime = os_tsk_create (TaskTime, 1); //tidAdc = os_tsk_create (TaskAdc, 0); os_evt_set (0x0001, tidLed); /* send signal event to task phaseA */ os_tsk_delete_self (); } //////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // int main (void) { CLK_SetClkOut(CLKSR_ICLK); GIO_OutEnBits(LED_GIO,LED_PIN,true); GIO_OutEnBits(KEY_GIO,KEY_PIN,false); os_sys_init (TaskInit); /* Initialize RTX and start init */ }
output form sci: ledoff = 1 it looks like os_itv_wait() stopped in flash mode,why?
in TaskSci, codes changed as follow, but problem remain.
for(;;){ len = strlen((char *)strSciBuf); if(len>0){ SCI2_SendBytes((u8 *)strSciBuf,len); strSciBuf[0]=0; } os_dly_wait(1); }
You set an event: os_evt_set (0x0001, tidLed); /* send signal event to task phaseA */
but the task seems not to accept an event due to you use a fixed timer.
http://www.keil.com/support/man/docs/rlarm/rlarm_os_itv_wait.htm http://www.keil.com/support/man/docs/rlarm/rlarm_os_evt_set.htm
Kasper
Hi. I change LCD from Trylys LCD 16x2 (TSB1G7000-E) to be Lumex LCM-SO1062 (16x2) I can not see any thing on LCD. Do I modify anything in code? Now i use TCP stack.
