I'm using a Keil MCB1700 v.1.2 and a Segger J-link. I stablished the connection through the Segger, but i receive an error when i try to enter in the debug: "Error: Flash Downloaded failed - target DLL has been cancelled"
Which is the problem? Thanks
Hi.
I had already solved the problem. I just installed the updated uVision from keil.com (that has updated DLL) and the programs compiled normally.
Thanks. Rafael
can you give me more detailled information? Please copy all text from the output window and paste it here as
< pre > text < /pre >
(Delete the spaces)
. BR, /th.
Are you using MDK-ARM? If yes, then check in "Utilities" Tab under "Target Options..." and verify whether correct Flash algorithm file is provided.
