I am using the RL-TCPNet library for TCP/IP implementation and I am having a few problems as mentioned below.
1. TCP/IP using Cross over Ethernet Cable- When I use the Cross over ethernet cable I am having no problems communicating with my board from the PC. (PC-Client, Board-Server). The board is configured as a Server with keep alive timeout of 120 seconds. This works just fine with no problems at all.
When I use a straight cable including a Hub, I notice that the board does not respond to any requests. At times I am able to connect to the board but immediately the board stops responding. The only change that I have done is
1. Replaced the cross over with a cable from PC to hub and hub to to the board. Is there any configuration change that I need to make?
I have DHCP and DNS disabled, because I am using static IP and no names.
Thanks!
Kailash
