I like this message very much, ohh! what's pitiful! it's 2 years ago. but I really hope the writer or someone can send VS51.exe. thanks!
My email zeeman2003@hotmail.com
It’s just a coding ability, not others. Of course, using which development tools is almost depend on your personal habit. But we should agree with that the good tool makes life easier. The book《code complete》will give more viewpoints
The IDE as productivity enhancing - you must be kidding.
The statement would be true if the IDEs did not force you to use inferior components in addition to the components that attract you.
In my opinion if an IDE does not allow e.g. the editor to be replaced by CodeWright, it is useless.
in another way: I will not use the Keil IDE till it a) allow me to use MY editor b) allow me to run 47 slightly different builds from the same source c) do not regularily get out of synch with the (e.g. SILabs) chip interface
I have enhanced my productivity by throwing the IDE away and using .bat files with 3 tabs on the taskbar (editor, .bat for build and emulator).
Well, a cynic would say, "If VS is so great, why would you need to add all these extras...?"
But, back to my question, that site says nothing whatsoever about what "refactoring" actually is! What does it actually mean?
It claims to make it easy - but it doesn't say what it is!
It just assumes that I want to "refactor" - it doesn't tell me why I might want to do that!
Refactor existing code making it easier to read and cheaper to maintain.
I can see that could be helpful in certain circumstances, but I can't see that it's going to make a 20-30% difference to my productivity on a day-to-day basis.
But maybe that's because I still don't really see what it means (yet). What's the Big Idea?
But how does it make it easier to read and cheaper to maintain?
You still haven't explained what "refactoring" actually is!
let me think a while o(︶︿︶)o
For C, you don't have much problem with scope.
It is quite trivial to do a search/replace within a single function as long as new variables aren't created in nested blocks.
For C++ with namespaces and classes, it can often be an idea to change the variable name to something really silly, like 'xx1253beep' and catch all compilation errors. Then it will be possible to do a global search/replace to the final name. This makes sure that a missed rename of a variable doesn't gets resolved by a global variable with the same name.
Giving all global variables a prefix can also often help out.
"Refactor existing code making it easier to read and cheaper to maintain."
What's happened to the skill of planning what you're going to write before actually writing it?
I believe it assumes you are lazy and do not make variables meaningful when you use them. IE it assumes 'you' do this
void fnc_me(unsigned char e) { int i; i = 0; for(;i < e; i++) { if(i & 1) { s_pf("%X", i);} else { s_pf("%03d", i); } } }
In other words you obfuscate everything to loose all meaning because you are too lazy to actually write coherent code (this could be a Microsoft internal problem).
And when you need to change a routine you just recycle the variable over and over each time. So no meaning is attached to any of your code. You also don't comment etc.
Basically it makes that assumption.
It's mostly helpful when you get another project that you can't make heads or tails of (and was written like my obfuscated example I guess) and you need to change it or update it significantly.
Stephen
Refactoring isn't just about renaming variables.
It is about rewriting the software in small and distinct steps, so that you every evening have stable code to release. Many companies don't allow software to be released without very significant testing, in which case the micro-step updates may possibly only be release points for regression testing.
But the refactoring includes splitting or merging of functions, redefinitions of data declarations etc, etc, etc. Without having spent any real time with never versions of VC, I'm not sure how many editing rules it supports, besides the search/replace logic.
Ok, I began to pragram from PC software, and then to MCU. So I would like MCU develpmen environment as alomst same as PC, Also I would like new technology of coding, Maybe this make me having diffrent view from others.
About coding I think the Book of CODE COMPLETE is great, it hase hundreds pages talk about, if someone like learn some new thing, would buy it.
About IDE or some Plug-ins may look at this WEB http://www.wholetomato.com/
About 20-30% difference to my productivity, look at the advertisement in the WEB I mentioned above, it say 50 times Times saving, maybe it's diffrent from 20-30%, my math is poor
Per Westermark makes point!
You don't honestly just believe everything you read in advertising, do you??!!
You still haven't managed to give any explanation of what "refactoring" actually is! So it's hard to beleive that it's been of any real benefit if you can't actually explain what it is!
I guess the language barrier may be an issue here but, even so, I think you should be able to explain something, or give some examples?
But, if the meaning is lost (or was never there in the first place), how can any automatic process (re-)create it?!
Isn't that just like trying to re-create 'C' source code from hex?
A 50 times time saving is 5000%.
But that would require that the developer spends a huge amount of time playing with the code after having initially written it. If the code takes 10 hours to write, you would have to spend 500 hours with it (besides debugging) to perform manual cleanup. If that time isn't available, then you can obviously not optimize it away.
If I pick up an old project, I can normally see more than 90% of the source lines having revision 1.1 in the source repository, indicating that there are very few lines that gets modified after having been initially written. That would then indicate that less than 10% of the code lines could take advantage of any code factoring. The total gain from a tool supporting code factoring would then be quite small.
When developing a product, it can be said that each step later in the development cycle that an error is caught, the cost will have increased with a factor 10. You do not want bugs or hw errors in the released product. You want to catch them during the design phase. Twice the time invested in the design phase is well invested money. And it removes the need for a lot of code rewrites during the lifetime of the product.
It is very good to have tools that helps correlating source code with the requirements specification. But it is dangerous when people looks for the source code editors that are quickest at rewriting code. Having large needs for code rewrites indicates large problems in the development process.
Yes, there is a language barrier ,Refactor is a coding technology, it's hard to explain for you, Maybe you can google to get point, or download trial from that site, to find what will happen
