Olimex LPC2888 + Ulink-ME
Hi Friends,
I am working on LPC2888 from Olimex. I am using Ulink-ME as the JTAG adapter.
The problem that i am facing is that it keeps popping up "Cannot load flash programming algorithm". Occasionally, the code gets downloaded.
Is there any workaround for this ?
But when i have written a statement to toggle a port pin for LED, it isn't working. I am using the latest code bundle software from NXP.
Am i missing something? Has anybody worked with Ulink-ME as JTAG adapter for this controller.
Is there any workaround for this?
Any help would be highly appreciated.
With regards,
PRashant
  • Hi Friends,
    I was finally able to see the port pin toggling through my code. The code that i used was the USBMem code given by Keil.
    But unfortunately, i was able to download it only once. After that i kept getting "JTAG communication Failure" constantly. I am using ULINK-ME as the JTAG adapter.
    Would there be anything in the code that disables the JTAG. Also i noticed that the ROM settings provided with Keil is somewhat different than the one provided by NXP.
    Pls let me know if there is any workaround. Is there any recovery mechanism for this ?
    With regards,
    Prashant
