i am trying to generate ECG waves using DAC in LPC2366 i need help
And what kind of help do you need? Do you stuck at installing the IDE?
Whew.
That was a tough request.
I've created a project, and uploaded to complete work onto a new website.
Find it at www.EcgWavesUsingDac.com
Enjoy.
Since your request does not contain enough informations, helping you is very hard. If you give sufficient informations, there will surely be someone around able to help.
i am able to generate sine wave using DAC.i want to know any kind of algorithm in order to generate ECG waves.LIke varying P,Q,R,S,T,U.
Maybe link.aip.org/.../ is interesting for you. If you are familiar with Matlab you can try physionet.fri.uni-lj.si/.../
i am not using matlab,instead i am planning to creats a look up table where in i can load in all the values and just display using DAC.
U wave appears just when some disorder occur, myocardial infarction, hypo-potassemia, severe hypertension, etc.
Start with ECG in normal range. Even generating all waves of 12-leads ECG is awful work.
Tsuneo
