ip address configuration
I have started to use the TCP/IP stack of the Real-Time Library and i have a question about the ip address configuration.
At present, the ip address defined in the file "net_config.c" and the ip address can't be changed after the program compiled.
Then,can i configure the ip address while the program running??
