hi, how do i compile a program in keil so that it can be debugged in proteus ? ELF/DWARF, OMF51, UBROF are the files supported by the debugging in proteus
if using the IDE ask again if commandline C51 [file] DB
"ELF/DWARF, OMF51, UBROF are the files supported by the debugging in proteus"
So you need to study the C51 Manual to see which option(s) exist to select any or all of those formats - don't you?
http://www.keil.com/support/man/docs/c51/c51_cm_dirlist.htm
You should also check with Proteus for any documentation they may have on how to configure Keil for use with their product...
"The following table lists the third party tools supported by Proteus VSM. For each tool we have indicated the Proteus VSM processor models supported and whether or not that support extends to source level code stepping and/or variable display. Specific support information for each tool can be found in the sections that follow."
www.labcenter.co.uk/.../compilers.cfm
