Hi Im new to Keil RVMDK, Im writing a simple program after creating a project for LPC2468 controller. Below are the steps I did:
1. Created a sample project (Assembly file lpc2400.s was automatically added) 2. then wrote a small source (main.c) and added to my project:below is the code snippet #include<stdio.h> #include<lpc23xx.h> main() {
int a=10,b=10,c=0; c=a+b;
Now I want to view the values in memory window and watch window, Im able to get values of a & b but not c. Also I need information on how control passes from startup file to my main.c (I think Its not happening in my case).The actual problem my sample code snippet is not running when i opened my debugger and press "run" button (It says error as undefined identifier).Please could anybody help me in solving this issue.
I can see variables in Watch window and it is updating when step-in, but how can I see values in Memory Window, If I give address of "a" in Memory Window It shows R0 / R1 (register) values. I need value 10 in memory window when I give address of variable "a". Could you please help me with this.
so start here:
http://www.keil.com/support/man/docs/gsac/
http://www.keil.com/support/man/docs/uv4/uv4_ex_hello.htm
http://www.keil.com/support/man/docs/uv4/uv4_examples.htm
#include<stdio.h> #include<lpc23xx.h> main() { int a=10,b=10,c=0; c=a+b; for (;;) ; }
have you noticed how the usage of pre and /pre tags improves the appearance of code?
