XC888 - LCD power up sequence....
In certain situations, my LCD will not power up.
I am using an Infineon XC-888 micro driving a 16x4 LCD in 4-bit mode.
The LCD is based on the ST7066U IC, the c-code is based on the DAvE structure.
LCD Datasheet:
www.sitronix.com.tw/.../ST7066Uv22.pdf
I have been playing around with software delays and timing, but in certain situations, the LCD will power up and others not.
Here are my observations so far:
When I re-program the device, there are no problems, it is always when power is removed... and then re-applied.
I have previously tried inserting a really long SW delay to give the lcd time to power up, but that doesn't work.
The "line LCD_init4bit();" is in 2 places in the code below, when the one inside the "while(1){...}" loop is removed, it will not power up when power is applied.
When the one outside the while loop is removed/commented out, and the one inside enabled, it works.
This also leads me to believe that there is nothing wrong with the function itself, but like I previously said, I have already tried long SW delays to give the LCD time to power up.
I am not sure about reset vectors or the compiler, but any suggestions would be muchly appreciated.
void main(void)
  // USER CODE BEGIN (MAIN_Main,2)
  // USER CODE END
  MAIN_vInit();
  // USER CODE BEGIN (MAIN_Main,3)
  //INT_vDisableAll();
  setOutputBits(PASS_LED + FAIL_LED);
  delay(1000);
  resetOutputBits(FAIL_LED);
  delay(100);
  LCD_init4bit();
  //INT_vEnableAll();
  // USER CODE END
  while(1)
  // USER CODE BEGIN (MAIN_Main,4)
  LCD_init4bit();
  resetOutputBits(PASS_LED);
  delay(10000);
  LCD_instruction4bit(CLEAR_DISPLAY);
  delay(1);
  LCD_sendstring4bit("Hello World");
  delay(1);
  delay(1);
  // USER CODE END
} //  End of function main
