Hi,I want to read in some data from for example hyperterminal and use it in uvision to further exucate in calculation etc.
Is it simply scanf(" %d , &etc) ???
Look at the example code for RTX-Blinky in the ...boards/keil/mcb2300 folder. It is an RTX example but it shows one method of keyboard input via UART. Bradford
you have to do some basic retargeting work. Search for a file called "retarget.c". You'll find more different files of it, from a very basic file up to a more deep retargeting.
The retargeting can be done on two levels: 1. fputc, fgetc 2. _sys_x functions
The stdio functions call (just an overview):
(f)printf --> fputc --> lib --> _sys_write (f)scanf --> fgetc --> lib --> _sys_read fopen --> lib --> _sys_open fclose --> lib --> _sys_close
If you'd like to have more detailed information on retargeting, please write an email to www.keil.com/.../gethelp.asp and I'll help with source code :-)
BR, /th.
Note that using scanf is not necessarily "simple" - irrespective of whether it's in an embedded target, or anywhere else!
Try searching this forum for "scanf"...
You might find it easier to develop your own parser - in particular for handling "unexpected" data and/or formatting...
Many Thanks for your help guys.
Basically I want to set up a menu type system for the mcb2300,so a command from the keyboard triggers the next stage of the program etc.
I do have the retarget.c and will give what you have suggested so far but will surely have a few more questions in the not so distant future.
thanks again
