I,m interfacing LPC2148 to PC through USB in the process of ennumeration after i recive set address command i send null packet n set address but then not getting setup packet for dd of 18 byte again getting set address
when i add to numbers i am getting the wrong answer.
example; a = 200; b = 210; c = a + b;
c is not 411.
what is the fault?
pls,. anyone know the fault? i must go to next fault very quickly.
... that you have hijacked this thread with a totally unrelated question!
You need to start you own, new for your own question.
... and refrain from hijacking a thread, I have the answer
So 200+210 is not coming out at 411.
"what is the fault?"
Tempting to say that it comes down to the schooling.
As of the original post, It's the same problem as this topic, http://www.keil.com/forum/docs/thread16271.asp
I don't like to repeat the same discussion here, join to above thread.
Anyway, is it a homework on a university course? Two different posters have the same problem at a time. If so, the teacher should know that, without a hardware bus analyzer, development of USB stack is just waste of time.
Tsuneo
we used usblyzer software but its not detecting the device.
Did you apply "automatic capture of hot plugged device" feature?
Or try SourceUSB with "hot plugged" feature. http://www.sourcequest.com/
SourceUSB misses the first Get_Descriptor, but it catches next Set_Address and later sequence.
1) bus reset 2) Get_Descriptor( DEVICE ) 3) bus reset 4) Set_Address 5) Get_Descriptor( DEVICE ) 6) Get_Descriptor( CONFIG ) ...
Hello, I'm implementing USB mass storage device on LPC2148. My device is now detected but the properties show RAW data format and when i try to open or explore the drive i get error "Your device should be formatted" if i click on Yes it again gives error "The device cannot be formatted" . So i want to convert the data on my device to a format readable by Windows XP so which format i should use? From where to start? From where i can get code for it? are such codes available? How they can be implemented? I don't want to use SD card. Ya and which system would you suggest FAT or NTFS? Thank you.
Answered in this thread. http://www.keil.com/forum/docs/thread16271.asp
