Hi all,
I have nothing in the Debug (printf) window dialog when I use the printf instruction. (UART #x too)
Is there something to initialize, or include a specific header? How the printf could be assigned to a specific port?
I'm simulating a simple programm running on an STM32 µc
thx
did you retarget fputc? see retarget.c, can be found in many projects.
When using CM3, retarget fputc to ITM_Sendchar (CMSIS), then you'll see the output in ITM/printf Viewer.
BR, /th.
I've just got this source and printf works now.
Thank You
np, have fun :-)
There is also a back channel implemented, where text typed in the ITM/Printf Viewer Window is sent to a memory location on the target (if a special Variable Name is found).
You may use it as follows: (Example, if you don't use RTX, just use the ITMRx_Getc() )
#include <RTL.h> /* RTX kernel functions & defines */ #include "itm_rx.h" #include "rx_buffer.h" volatile unsigned int ITM_RxBuffer; // 0x5AA55AA5 is handshake value // ITM Serial Window Input Watch and Init function void ITMRx_InInit(void) { ITM_RxBuffer = 0x5AA55AA5; } int ITMRx_Getc(void) { int recChar=0; // zero is default if no new char recv if(ITM_RxBuffer != 0x5AA55AA5) { recChar = ITM_RxBuffer & 0xff; ITM_RxBuffer = 0x5AA55AA5; } return(recChar); } __task void ITMRx_GetcWatch(void) { int tmp; os_itv_set (1); // 10 ms while(1) { tmp = ITMRx_Getc(); if(tmp) itm_rxBuffer_putchar(tmp & 0xFF); // write buffer os_itv_wait (); } }
Note: For usage with scanf() (fgetc() - retarget) you should add a blocking wrapper calling ITMRx_Getc(), because it returns 0 when no new char is avaiable.
