USB Mouse with Scroll Wheel
Dear All,
I want to write a HID Mouse Driver using LPC2148 controller. I re-worked on the example given by Keil HID and was able to detect the board as USB Mouse. This mouse has only three buttons(left, middle and right) and send three bytes of InReport.
I would like to extend this for mouse with scroll wheel.
Do i have to change any descriptors for this? if yes, what and where. What will be the InReport size and Which byte will correspond to the scroll wheel movement..
Thanks...
Yashath
  • > Do i have to change any descriptors for this?
    Report descriptor, to add the field for the wheel.
    See this MS web page, and attached DOC, for the details of vertical and horizontal wheel.
    "Enhanced Wheel Support in Windows Vista" on MS WHDC
    www.microsoft.com/.../wheel.mspx
    This is an example Report Descriptor, originally I posted to Microchip forum,
    " on MS WHDC // www.microsoft.com/.../wheel.mspx // const BYTE HID_ReportDescriptor[] = { 0x05, 0x01, // USAGE_PAGE (Generic Desktop) 0x09, 0x02, // USAGE (Mouse) 0xa1, 0x01, // COLLECTION (Application) 0x09, 0x02, // USAGE (Mouse) 0xa1, 0x02, // COLLECTION (Logical) 0x09, 0x01, // USAGE (Pointer) 0xa1, 0x00, // COLLECTION (Physical) // ------------------------------ Buttons 0x05, 0x09, // USAGE_PAGE (Button) 0x19, 0x01, // USAGE_MINIMUM (Button 1) 0x29, 0x05, // USAGE_MAXIMUM (Button 5) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x25, 0x01, // LOGICAL_MAXIMUM (1) 0x75, 0x01, // REPORT_SIZE (1) 0x95, 0x05, // REPORT_COUNT (5) 0x81, 0x02, // INPUT (Data,Var,Abs) // ------------------------------ Padding 0x75, 0x03, // REPORT_SIZE (3) 0x95, 0x01, // REPORT_COUNT (1) 0x81, 0x03, // INPUT (Cnst,Var,Abs) // ------------------------------ X,Y position 0x05, 0x01, // USAGE_PAGE (Generic Desktop) 0x09, 0x30, // USAGE (X) 0x09, 0x31, // USAGE (Y) 0x15, 0x81, // LOGICAL_MINIMUM (-127) 0x25, 0x7f, // LOGICAL_MAXIMUM (127) 0x75, 0x08, // REPORT_SIZE (8) 0x95, 0x02, // REPORT_COUNT (2) 0x81, 0x06, // INPUT (Data,Var,Rel) 0xa1, 0x02, // COLLECTION (Logical) // ------------------------------ Vertical wheel res multiplier 0x09, 0x48, // USAGE (Resolution Multiplier) 0x15, 0x00, // LOGICAL_MINIMUM (0) 0x25, 0x01, // LOGICAL_MAXIMUM (1) 0x35, 0x01, // PHYSICAL_MINIMUM (1) 0x45, 0x04, // PHYSICAL_MAXIMUM (4) 0x75, 0x02, // REPORT_SIZE (2) 0x95, 0x01, // REPORT_COUNT (1) 0xa4, // PUSH 0xb1, 0x02, // FEATURE (Data,Var,Abs) // ------------------------------ Vertical wheel 0x09, 0x38, // USAGE (Wheel) 0x15, 0x81, // LOGICAL_MINIMUM (-127) 0x25, 0x7f, // LOGICAL_MAXIMUM (127) 0x35, 0x00, // PHYSICAL_MINIMUM (0) - reset physical 0x45, 0x00, // PHYSICAL_MAXIMUM (0) 0x75, 0x08, // REPORT_SIZE (8) 0x81, 0x06, // INPUT (Data,Var,Rel) 0xc0, // END_COLLECTION 0xa1, 0x02, // COLLECTION (Logical) // ------------------------------ Horizontal wheel res multiplier 0x09, 0x48, // USAGE (Resolution Multiplier) 0xb4, // POP 0xb1, 0x02, // FEATURE (Data,Var,Abs) // ------------------------------ Padding for Feature report 0x35, 0x00, // PHYSICAL_MINIMUM (0) - reset physical 0x45, 0x00, // PHYSICAL_MAXIMUM (0) 0x75, 0x04, // REPORT_SIZE (4) 0xb1, 0x03, // FEATURE (Cnst,Var,Abs) // ------------------------------ Horizontal wheel 0x05, 0x0c, // USAGE_PAGE (Consumer Devices) 0x0a, 0x38, 0x02, // USAGE (AC Pan) 0x15, 0x81, // LOGICAL_MINIMUM (-127) 0x25, 0x7f, // LOGICAL_MAXIMUM (127) 0x75, 0x08, // REPORT_SIZE (8) 0x81, 0x06, // INPUT (Data,Var,Rel) 0xc0, // END_COLLECTION 0xc0, // END_COLLECTION 0xc0, // END_COLLECTION 0xc0 // END_COLLECTION };
