OK, what silly mistake have I made this time..?
I have just downloaded uVision4. Got a simple bit of code to flash and LED on and off.
However, I cannot single step through the code. When I hit Start/Stop Debug session, all other option get greyed out. .
I seem to have gone through all the project options as well as copying my code to a new project. It looks like my problem is similar to Benjamin's (recently posted). tried all his fixes and still nothing works
Here is my code:
#define at91sam7s256 #include <at91sam7s256.h> #define LED (1<<0) // PA0 #define BUTTON1 (1<<19) // PA19 static void initialize( void); int main(void) { volatile long input; volatile int n; volatile AT91PS_PIO pPIOA = AT91C_BASE_PIOA; initialize(); while(1) { input = (pPIOA->PIO_PDSR) & BUTTON1; input = 0; input = BUTTON1; if (((pPIOA->PIO_PDSR) & BUTTON1) == BUTTON1) { pPIOA->PIO_SODR = LED; } else { pPIOA->PIO_CODR = LED; input = (pPIOA->PIO_PDSR) & BUTTON1; } } } static void initialize(void) { //Turn on the peripheral clock. Without this on, inputs do not actually register in the PDSR register volatile AT91PS_PMC pPMC = AT91C_BASE_PMC; // pointer to PMC data structure volatile AT91PS_PIO pPIOA = AT91C_BASE_PIOA; pPMC->PMC_PCER = (1<<AT91C_ID_PIOA); // enable parallel IO controller clock pPIOA->PIO_PER = (LED | BUTTON1); // Set PIO to control LED and button. // Initialize Input pPIOA->PIO_ODR = BUTTON1 ; // Disable outputs for INPUT pins. (not needed as all pins default input on reset) pPIOA->PIO_PPUER = BUTTON1; //Pullup Enable (not needed as all pullups are enabled on reset) // Initialize Output pPIOA->PIO_OER = LED; // Enable output for LED. pPIOA->PIO_SODR = LED; // Turn LED off. pPIOA->PIO_PPUDR = LED; //Pullup disable }
Please let me know
