I just upgraded from version 3.80 RL-ARM, RVMDK to version 4.0 and all of the sudden some of my software interrupt functions have stopped working.
My problem seems to be an issue with a SWI function that has a return value. [NOTE: I had no issues with this in 3.80]. What ends up happening is that the stack pointer gets corrupted and SWI_Handler( ) is not able to properly restore the CPSR
This is my swi function:
unsigned int __swi(0x08) pmalloc (int size) ; unsigned int __SWI_8 (int size) { NUMpmalloc++; return ((unsigned int)malloc(size)); // Protected malloc }
Here's where the problem occurs in SWI_Handler( )
{ . . . L250: MOV LR,PC ; Return Address L251: BX R12 ; Call SWI Function L252: LDMFD SP!,{R8,PC}^ ; Restore R8 and Return }
L251 is where the SWI function gets called. The problem is that the stack pointer value at L251 does not equal the stack pointer value at L252, so when the function attempts to return back to my code things don't work properly. This version 4 SWI_Handler( ) function is the same as the SWI_Handler ( ) function from version 3.8
Any thoughts you might have would be greatly appreciated!
Thanks, Eric
