Hello. I am working on porting some code for the nRF24E1 from the SDCC compiler to the Keil compiler. I have the code compiling fine, but I had to comment out some inline assembly functions that are used for a time delay. Can anyone offer any suggestions on getting the inline assembly working properly? This code works fine in the SDCC compiler but I am having problems getting it to compile correctly in the Keil Compiler. The delay function is used for minimum time delays. Below is my code.
void Delay1us(unsigned char i) // n from 1 - 255 = n(us) + 4(us) Delay { // n = 0 = 256 + 4us = 260us Delay @ 16Mhz Clock // 16 Cycle Overhead and 4 Cycle Loop count = i; asm MOV R7, _count // Two Instruction Cycles @ 16MHz = 500nS LOOP: nop // One Instruction Cycle djnz R7, LOOP // Three Instruction Cycles @ 16Mhz = 750nS endasm; }
Below is my information about microVision and Keil compiler.
IDE-Version: µVision3 V3.72 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2008
Tool Version Numbers: Toolchain: C51 Compiler/Assembler Kit Version: 8.17 Toolchain Path: C:\Keil\C51\BIN\ C Compiler: C51.Exe V8.17 Assembler: A51.Exe V8.01 Linker/Locator: BL51.Exe V6.15 Librarian: LIB51.Exe V4.24 Hex Converter: OH51.Exe V2.6 CPU DLL: S8051.DLL V3.64 Dialog DLL: DP51.DLL V2.53
Please let me know if anyone has any suggestions or comments. Thanks for your help.
I think it is #asm. But, it is in the manual. Note the calculations at the beginning of the subroutine may not match Keil.
You may want to do the entire subroutine in ASM. It depends on how accurate you need it to be.
