Hello, I've got serious problems with the uVision4 starting a debug session.
1. I hit the debug button in the toolbar. 2. uVision4 starts to upload the programmcode. 3. After successfull upload it says Window Layout in the statusbar and here the trouble start: Sometimes it takes uVision several seconds to get the windows setup. Sometimes it takes way over 30 seconds until uVision4 is ready to debug and sometimes uVision just crashes or freezes.
I must say this is quite an annoying problem with the uVision4 IDE. I like what I've seen so far except this serious problem!
Will this get fixed and is anyone else having similar problems?
Greetings Jan
Jan; I have not seen this particular problem. What version of MDK are you running? Have you reported this bug to Keil Support? They will need full info of your toolset and your computer enviornment. Remember that Keil does not check this forum on a regular basis. Bradford
Hello Bradford, I am using the following toolchain: IDE-Version: µVision V4.00 Beta 3.1 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009
Tool Version Numbers: Toolchain: RealView MDK-ARM: x user Version: 3.80a Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.0.0.524 Assembler: Armasm.Exe V4.0.0.524 Linker/Locator: ArmLink.Exe V4.0.0.524 Librarian: ArmAr.Exe V4.0.0.524 Hex Converter: FromElf.Exe V4.0.0.524 CPU DLL: SARMCM3.DLL V3.80a Dialog DLL: DARMSTM.DLL V1.43 Target DLL: BIN\UL2CM3.DLL V1.50 Dialog DLL: TARMSTM.DLL V1.43
I am contacting the technical support. I tried to gather as much informations as possible first. Best regards! Jan
