my secondary bootloader is working ok with normal application. but when i used with ucosii application its stuck in task1.
memory map is
for bootloader-0x00000000 0x00010000 application 0x00010000 0x00080000
for copying vector to ram i have used IF :DEF:RAM_INTVEC ADR R8, Vectors ; Source LDR R9, =RAM_BASE ; Destination LDMIA R8!, {R0-R7} ; Load Vectors STMIA R9!, {R0-R7} ; Store Vectors LDMIA R8!, {R0-R7} ; Load Handler Addresses STMIA R9!, {R0-R7} ; Store Handler Addresses ENDIF
please help me
please provide me startup code that can be used.
thanks and regards pranam gharat
use RAM_INTVEC REMAP RAM_MODE in the ASM tab "Define" field to remap the vectors to internal RAM.
i already using this RAM_INTVEC REMAP RAM_MODE
my program is starting also upto intialisation but when tasking start it get stuck.
my bootloader is not with ucosii it is simple application
my scatter is LR_IROM1 0x00010000 0x00080000 ;; Load region { ER_IROM1 0x00010000 0x00080000 { vectors.o (VECT, +First) init.o (INIT) * (+RO) }
RW_IRAM1 0x40000040 0x00008000 { * (+RW,+ZI) } ;; The following declarations select the "two region model" ; ;; A default __user_initial_stackheap() will be used ; ARM_LIB_HEAP 0x40007000 EMPTY 0x00000100 {} ARM_LIB_STACK 0x40008000 EMPTY -0x00000E00 {}
please replay
