Hi All
I'm hoping someone might be able to help me out....
I'm not 100% sure about this...
Can anyone tell me please Does the Keil RL-FLASHFS library support SD cards connected via the SDIO port ?
If it doesn't what solutions have people implemented ?
Anbeyon
"Can anyone tell me please Does the Keil RL-FLASHFS library support SD cards connected via the SDIO port ?"
I'm sure Keil could tell you that - have you asked them?
You would probably need to state which specific "SDIO port" you're talking about...
"what solutions have people implemented ?"
This one, with SPI: elm-chan.org/.../00index_e.html
Hi thanks for the reply!
I have looked at the link you posted - thannks. Unfortunately the board I have to work on is built for SD access to run from the SDIO port.
I will contact Keil direct. I just thought I might get an answer quicker here.
