LPC1114 SPI1 Help...
I am using LPC1114.
I want to interface LIS302DL Accelerometer with LPC1114. For that purpose I have chosen SPI.
I am not getting proper X,Y,Z values... I am getting default value 255 i.e ff
The following is my code,anyone please help me out....
#include "LPC11xx.h"
#include"system_LPC11xx.c"
#include"stdio.h"
#include"Retarget.c"
#define SystemCoreClock 12000000UL
#define FIFOSIZE                8
/* SSP Status register */
#define SSPSR_TFE               (1 << 0)
#define SSPSR_TNF               (1 << 1)
#define SSPSR_RNE               (1 << 2)
#define SSPSR_RFF               (1 << 3)
#define SSPSR_BSY               (1 << 4)
#define SPI_CS 0 // port 2
typedef unsigned char uc;
typedef unsigned int ui;
void UARTInit   (ui);
int  sendchar   (int ch);
int  getkey             (void);
void delay              (void);
void    SPI_Init        (void);
uc      SPIReceive      (uc);
void    SPISend         (uc,uc);
ui  RECV,regVal,X,Y,Z,i,who;
int main (void)
        SystemInit();   // for initializing clocks
        UARTInit(9600); // for serial & Printf communication
        SPI_Init();
        printf("Hi \n");
        printf("Testing SPI ...\n");
        SPISend(0x20,0x47);
        delay();
        while(who!=0x3B)
        SPISend(0x20,0x47);
        who=SPIReceive(0x0f);
        printf("who_am_i=%x \n",who);
        delay();
        while(1)
                delay();
                X=SPIReceive(0x29);
                Y=SPIReceive(0x2B);
                Z=SPIReceive(0x2D);
                printf("X=%d Y=%d Z=%d \n",X,Y,Z);
/*====================================SPI==============================================*/
void SPI_Init()
                uint8_t i, Dummy=Dummy;
                LPC_SYSCON->PRESETCTRL |= (1<<2);
                LPC_SYSCON->SYSAHBCLKCTRL |= (1<<18);  // clk for spi1
                LPC_SYSCON->SSP1CLKDIV = 0x02;               /* Divided by 2 */
                /*  SSP I/O config */
                LPC_IOCON->PIO2_3           &= ~0x07;
                LPC_IOCON->PIO2_3           |=  0x02;                /* SSP1 MOSI */
                LPC_IOCON->PIO2_2           &= ~0x07;
                LPC_IOCON->PIO2_2           |=  0x02;                /* SSP1 MISO */
                LPC_IOCON->PIO2_1           &= ~0x07;
                LPC_IOCON->PIO2_1           |=  0x02;                /* SSP1 CLK */
                LPC_IOCON->PIO2_0           &= ~0x07;
                LPC_IOCON->PIO2_0           |=  0x02;                /* SSP1 SSEL */
        /* SSPCPSR clock prescale register, master mode, minimum divisor is 0x02 */
                LPC_SSP1->CPSR = 0x2;
        /* Set DSS data to 8-bit, Frame format SPI, CPOL = 0, CPHA = 0, and SCR is 15 */
                LPC_SSP1->CR0 = 0x0707;
                for ( i = 0; i < FIFOSIZE; i++ )
                Dummy = LPC_SSP1->DR;                /* clear the RxFIFO */
                LPC_SSP1->CR1 |= 2;  /* Enable SSP */
                return;
void SPISend( uc Radd,uc Rval )
                uint8_t Dummy=Dummy;
                Radd&=0x7F;
                /* Move on only if NOT busy and TX FIFO not full. */
                while ( (LPC_SSP1->SR & (SSPSR_TNF|SSPSR_BSY)) != SSPSR_TNF );
                LPC_SSP1->DR = Radd;
                while ( (LPC_SSP1->SR & (SSPSR_BSY|SSPSR_RNE)) != SSPSR_RNE );
                LPC_SSP1->DR = Rval;
                return;
unsigned char SPIReceive(uc Radd)
        unsigned char SPIRECV;
        Radd|=0x80;
        //LPC_GPIO2->MASKED_ACCESS[(1<<SPI_CS)] = (0<<SPI_CS);   // cs=0
        while ( LPC_SSP1->SR & SSPSR_BSY );
        LPC_SSP1->DR = 0xFF;
        SPIRECV = LPC_SSP1->DR;
        return SPIRECV;
/*======================================UART=============================================*/
void UARTInit(ui baudrate)
        LPC_IOCON->PIO1_6 &= ~0x07;                      /*  UART I/O config */
        LPC_IOCON->PIO1_6 |= 0x01;                           /* UART RXD */
        LPC_IOCON->PIO1_7 &= ~0x07;
        LPC_IOCON->PIO1_7 |= 0x01;                           /* UART TXD */
        LPC_SYSCON->SYSAHBCLKCTRL |= (1<<12);  // UART CLK enable
        LPC_SYSCON->UARTCLKDIV = 0x01;               /* divided by 1 , like pre-scaler*/
        LPC_UART->LCR = 0x83;                        /* DLB=1, 8 bits, no Parity, 1 Stop bit */
                /*baud rate */
        LPC_UART->DLM = ((SystemCoreClock)/(16*baudrate))/(256);
        LPC_UART->DLL = ((SystemCoreClock)/(16*baudrate))%(256);// Lower byte
        LPC_UART->LCR = 0x03;        /* DLAB = 0 ,Disable access to divisor latches*/
        LPC_UART->FCR = 0x07;        /* Enable and reset TX and RX FIFO. */
        regVal = LPC_UART->LSR;      /* Read to clear the line status. */
        return;
int sendchar(int ch)
        LPC_UART->THR = ch;
        while ( !(LPC_UART->LSR & 0x40) ); //wait until TEMT=0,i.e. U0THR contains valid data
        return 0;
int getkey()
        while(!(LPC_UART->LSR & (0x01)));
        RECV=LPC_UART->RBR;
        return RECV;
void delay()
        int i;
        for(i=0;i<=1005535;i++);
Thanks in advance.
