LPC23XX - Using External interrupt EINT0
Hi !
I am confused about using external interrupt. I have a MCB2300 board and wanted to write an application that use the push button wired to P2.10. In first step the interrupt handler just toggle led0.
In the user manual §10.2.2 we can read that P2 and P0 can both generate interrupts on each pin, on falling/rising edge.
So in order to use P2.10 as interrupt the register to use for me was those in table 133 & 134 "GPIO interrupt register map".
FIODIR Fast GPIO Port Direction control register.
IntEnR : GPIO Interrupt Enable for Rising edge.
IntClr GPIO Interrupt Clear.
Whith PINSEL4 we select the P2.10 pin mode : EINT0 or GPIO. I selected EINT0
But When I tested I see that the interrupt generated was not cleared by IntClr register.
Then I saw in forum that register to use for EINT are EXTINT, EXTMODE, EXTPOLAR, documented at §3.6.
So the question is : what is the difference beetween EINT0-3 and the GPIO interrupt handled by IntEnR/IntClr ? (Except that register to use are not the same :) )
Why is there "only" four external interrupt when the P0 & P2 can offer interrupt on each pin (that means 62).
