problems with 89c2051 programming in keil
i m doing a traffic signal project using 89c2051..now when i run my (assembly lang) program it gives two errors in keil...
program is as follows>>>(i have marked the lines where i got error)
INCLUDE REG_52.PDF <<<<<<<<<<<<<<<<<<<<<error SYNTAX ERROR (i used $mod51 syntax then)
NR EQU P3.5
NY EQU P3.4
NG EQU P3.3
SR EQU P1.2
SY EQU P1.3
SG EQU P1.4
ER EQU P1.5
EY EQU P1.6
EG EQU P1.7
WR EQU P3.7 <<<<<<<<<<<<<<<<<<<error ( ATTEMPT TO DEFINE AN ALREADY DEFINED SYMBOL)
WY EQU P1.0
WG EQU P1.1
CSEG AT 0 ; RESET VECTOR
; PROCESSOR INTERRUPT AND RESET VECTORS
ORG 00H ; Reset JMP MAIN
MAIN: MOV SP,#40H MOV P1,#0FFH MOV P3,#0FFH
TOP: CLR NR CLR SR CLR ER CLR WY SETB WG CALL Y_DELAY SETB NR CLR NY CLR WR SETB WY CALL Y_DELAY SETB NY CLR NG CALL DELAY
CLR NY SETB NG CALL Y_DELAY CLR NR SETB NY SETB SR CLR SY CALL Y_DELAY SETB SY CLR SG CALL DELAY
CLR SY SETB SG CALL Y_DELAY CLR SR SETB SY SETB ER CLR EY CALL Y_DELAY SETB EY CLR EG CALL DELAY
CLR EY SETB EG CALL Y_DELAY CLR ER SETB EY SETB WR CLR WY CALL Y_DELAY SETB WY CLR WG CALL DELAY AJMP TOP
DELAY: MOV R3,#3FH
REPA3: MOV R1,#0FFH
REPA2: MOV R2,#0FFH
REPA1: NOP DJNZ R2,REPA1 DJNZ R1,REPA2 DJNZ R3,REPA3 RET
Y_DELAY: MOV R3,#1AH
RQPA3: MOV R1,#0FFH
RQPA2: MOV R2,#0FFH
RQPA1: NOP DJNZ R2,RQPA1 DJNZ R1,RQPA2 DJNZ R3,RQPA3 RET
;********************************************************** END
