I am using LPC1114.
I have configured P0.1 as CLKOUT pin,but in simulation , it is not showing that pin as CLKOUT pin and instead it is showing it as 'reserved'
the following my code
#include "LPC11xx.h" #define IER_RBR 0x01 #define IER_THRE 0x02 #define IER_RLS 0x04 #define LSR_RDR 0x01 #define LSR_THRE 0x20 #define BUFSIZE 0x40 #define SystemFrequency SystemCoreClock #define SystemCoreClock 12000000UL void UARTInit(unsigned int Baudrate); void UARTSend(void); void UARTRecv(void); volatile unsigned char UARTBuffer[40],RECV; int main (void) { UARTInit(9600); while (1) { UARTRecv(); UARTSend(); } } /*=========================================================================================*/ void UARTInit(unsigned int baudrate) { unsigned int regVal; unsigned int Fdiv; LPC_IOCON->PIO1_6 &= ~0x07; /* UART I/O config */ LPC_IOCON->PIO1_6 |= 0x01; /* UART RXD */ LPC_IOCON->PIO1_7 &= ~0x07; LPC_IOCON->PIO1_7 |= 0x01; /* UART TXD */ LPC_GPIO0->DIR |= (1<<1); LPC_IOCON->PIO0_1 &= ~0x07; /* UART I/O config */ LPC_IOCON->PIO0_1 |= 0x01; /* clock out*/ LPC_SYSCON->SYSPLLCLKSEL = 0x00; //0-IRC,1-SYS Osc LPC_SYSCON->SYSPLLCLKUEN = 0x01; LPC_SYSCON->SYSPLLCLKUEN = 0x00; LPC_SYSCON->SYSPLLCLKUEN = 0x01; LPC_SYSCON->MAINCLKSEL = 0x00; //0-IRC Osc,1-PLL i/p,2-WDT,3-PLL o/p LPC_SYSCON->MAINCLKUEN = 0x01; LPC_SYSCON->MAINCLKUEN = 0x00; LPC_SYSCON->MAINCLKUEN = 0x01; while (!(LPC_SYSCON->MAINCLKUEN & 0x01)); LPC_SYSCON->CLKOUTCLKSEL = 0x00; // 0-IRC,1-Sys Osc,2-WD Osc,3-Main clk LPC_SYSCON->CLKOUTCLKSEL = 0x01; LPC_SYSCON->CLKOUTCLKSEL = 0x00; LPC_SYSCON->CLKOUTCLKSEL = 0x01; LPC_SYSCON->SYSPLLCTRL = 0x00000180; LPC_SYSCON->SYSAHBCLKCTRL |= (1<<12); // UART CLK enable LPC_SYSCON->UARTCLKDIV = 0x01; /* divided by 1 , like pre-scaler*/ LPC_UART->LCR = 0x83; /* DLB=1, 8 bits, no Parity, 1 Stop bit */ regVal = LPC_SYSCON->UARTCLKDIV; Fdiv = (((SystemCoreClock/LPC_SYSCON->SYSAHBCLKDIV)/regVal)/16)/baudrate ; LPC_UART->DLM = Fdiv / 256; LPC_UART->DLL = Fdiv % 256; LPC_UART->LCR = 0x03; /* DLAB = 0 ,Disable access to divisor latches*/ LPC_UART->FCR = 0x07; /* Enable and reset TX and RX FIFO. */ regVal = LPC_UART->LSR; /* Read to clear the line status. */ return; } void UARTSend() { LPC_UART->THR = RECV; while ( !(LPC_UART->LSR & 0x40) //wait until TEMT=0,i.e. U0THR contains valid data } void UARTRecv() { while(!(LPC_UART->LSR & (0x01))); RECV=LPC_UART->RBR; }
Please anyone answer these:
1. Is this code correct in using clocks? 2. I'm not getting 12Mhz signal at P0.1,why? 3. Using this snippet I want to test serial communication,but I'm getting simulation o/p only. I am not getting o/p from micro controller after dumping. why?
