..External Interrupt..INT0
hello all,
I am working with AT89C51CC01 which based on 8051.
I had write one program of external interrupt. See the code as follows.
void ex0_isr (void) interrupt 0
        CCAP1H = 0x5A;  // 35% Duty Cycle
void main (void)
//Configure INT0 (external interrupt 0) to generate an interrupt on the falling-edge of /INT0 (P3.2).
//Enable the EX0 interrupt and then enable the global interrupt flag.
        CMOD = 0x02; // Setup PCA timer
        CL = 0x00;
        CH = 0x00;
        CCAP1H = 0x10; // 75% Duty Cycle
        CCAPM1 = 0x42; // Setup PCA module 1 in PWM mode.
        IT0 = 1;   //  falling edge on /INT0 (P3.2)
        EX0 = 1;   // Enable EX0 Interrupt
        EA = 1;    // Enable Global Interrupt Flag
        CR = 1; // Start PCA Timer.
        while (1)
In this code without interrupt Duty cycle of PWM signal is 75% and when interrupt occur then Duty cycle is 35%.
This program works perfectly.
Is there possible to after interrupt then after some time program run normally (Same like without interrupt).
For example i want after interrupt after 5 min i come again into the same program routin.
Please give ur suggestion related to this problem.
Thanks in advance
