hello all, I am working with AT89C51CC01 which based on 8051. I had write one program of external interrupt. See the code as follows.
void ex0_isr (void) interrupt 0 { CCAP1H = 0x5A; // 35% Duty Cycle } void main (void) { //Configure INT0 (external interrupt 0) to generate an interrupt on the falling-edge of /INT0 (P3.2). //Enable the EX0 interrupt and then enable the global interrupt flag. CMOD = 0x02; // Setup PCA timer CL = 0x00; CH = 0x00; CCAP1H = 0x10; // 75% Duty Cycle CCAPM1 = 0x42; // Setup PCA module 1 in PWM mode. IT0 = 1; // falling edge on /INT0 (P3.2) EX0 = 1; // Enable EX0 Interrupt EA = 1; // Enable Global Interrupt Flag CR = 1; // Start PCA Timer. while (1) { } }
In this code without interrupt Duty cycle of PWM signal is 75% and when interrupt occur then Duty cycle is 35%. This program works perfectly.
Is there possible to after interrupt then after some time program run normally (Same like without interrupt). For example i want after interrupt after 5 min i come again into the same program routin. Please give ur suggestion related to this problem.
Thanks in advance
Use a timer to either generate interrupts or step down a counter that your main() looks at. Use this to modify the PWM configuration.
But how...?? if possible then give me some example program for External interrupt handle with Timer. Or just change in my program which i had wrote in my first thread.
http://www.keil.com/download/list/c51.htm
Why have an external interrupt for a 5 min action? External interrupts are normally used for external events - not for timed events.
But if you really want to, you could draw a GPIO pin to your external interrupt signal, and have your program toggle the GPIO after 5 minutes. That is a very strange and complex way to force an external interrupt - and a quite silly way to design a system.
Isn't it _way_ better to skip the external interrupt handler and just have a timer interrupt? Let's say your timer interrupt ticks every 10ms, i.e. 100 times/second. So after 500 ticks, 5 seconds have passed. Then rewrite the contents of the PWM register - just copy the code line you now have in your external interrupt handler.
hello all, Thanks for ur reply.
I have one another task to do with External interrupt Just see the code
#include "reg_c51.h" unsigned char ex0_count = 0; unsigned char ex1_count = 0; void ex0(void) interrupt 0 { ex0_count++; // Increment the counter } void ex1(void) interrupt 2 { ex1_count++; // Increment the counter } void main (void) { IT0 = 1; // Configure interrupt 0 IT1 = 1; // Configure interrupt 1 EX0 = 1; // Enable EX0 Interrupt EX1 = 1; // Enable EX1 Interrupt EA = 1; // Enable Global Interrupt Flag CMOD = 0x02; // Setup PCA timer CL = 0x00; CH = 0x00; if (ex0_count > ex1_count) { CCAP1H = 0x5A; } // 35% Duty Cycle else if (ex0_count < ex1_count) { CCAP1H = 0x99; } // 60% Duty Cycle else { CCAP1H = 0x10; } // 75% Duty Cycle CCAPM1 = 0x42; // Setup PCA module 0 in PWM mode. CR = 1; // Start PCA Timer. while (1) {} } This program runs but gives only else part which is 75% of PWM. But i want to do like if first time external interrup occurs then both ex0_counter and ex1_counter start to increment..then when 2nd time interrupt occurs then stop the counter increment. So after 2nd interrupt i have fix value in both counters. In main i compare this counter values n generate PWM accourding to comparision. In interrupt function i just write counter increment but i want if first time interrupt occurs then counter start to increment and when 2nd time interrupt occurs then stop the counter incrementation. Can i give both situation for same interrupt..?? I don´t have any idea for this task. Please give me ur idea or suggestion for this question. Thanks in advance
