i2c
dear all,
i m interfacing 24c16an with c8051f120. i have sck and sda on p0.6 and p0.7
when i dont enable the crossbar for smbus, these lines toggle as normal port pins
but when i enable the crossbar that time my smb0cr register is configured at 100Khz i.e i m using communication at 100Khz
but still i notice that SCK line doesnot toggle as clock line
it is steady at 3V i.e supply to ic.
i check the hardware, there is no short to any supply
i did P0 = 0xff as initialisation, and made then open drain.
but still the sck line is steady, no clock seen on it.
due to this i get NAK and my communication stops
pls suggest the solution. in case any doubts pls let me know
thank you all
