I try to format an SD_CARD with the LPC2368 and RL-ARM 3.40 with :
fformat ("M:SD_CARD /FAT32");
It doesn't work and I don't understand why.
Somebody can help me ?
can you try using SD_File example for the microcontroller that you are using and try in command line "format SD_CARD /FAT32" and see if that works? Did you make any changes to the code?
