Is there any options to burn the code directly from the Keil compiler through the serial ports. I am using Winbond w77le532 with 2 serial ports.And how to use Mon51 for debugging guide me plz.
No, not directly from the Compiler.
But you can get uVision to do it by invoking an external downloader utility; for an example, see: http://www.keil.com/appnotes/docs/apnt_159.asp
Thanks....But does Winbond controller have such downliad utility??...I am also in search of it..Kindly help me..
you may have to resort to a very outmoded method: read the datasheet
I know, only us old farts do such things, but I believe you may have to do this ardourous chore
