Hi everyone, I am using the silicon labs 8051 based C8051F060 controller. I want to load hex file into controller which is soldered into PCB. I am uing TQFP100 Pin controller. Can anyone suggest me the programmer (burner) (Distributor in india) for the same?
Use the SiLabs JTAG/Debug adaptor thingy?
note that this has nothing specifically to do with Keil - have you asked SiLabs?
Thanks for reply. No i haven't asked SiLabs. I want to use keil IDE and Compiler for code development.
Can I directly program the C8051F060 MCU from keil IDE with Silabs JTAG adapter (which you have mentioned).
How to Connect the JTAG adapter?
From where i can buy the JTAG adapter?
From SiLabs! (or your local distributor)
"How to Connect the JTAG adapter?"
Follow the instructions when you get it?
"Can I directly program the C8051F060 MCU from keil IDE with Silabs JTAG adapter (which you have mentioned)."
Yes.
Maybe you would view the sample design from Silabs.
In order to use Keil to develop the Silabs MCU, you should download a driver available from the Silabs website. After installing it, you could select it as your debug target in the Keil project property page.
