Hi everyone, I am using the silicon labs 8051 based C8051F060 controller. I want to load hex file into controller which is soldered into PCB. I am uing TQFP100 Pin controller. Can anyone suggest me the programmer (burner) (Distributor in india) for the same?
Use the SiLabs JTAG/Debug adaptor thingy?
note that this has nothing specifically to do with Keil - have you asked SiLabs?
Thanks for reply. No i haven't asked SiLabs. I want to use keil IDE and Compiler for code development.
Can I directly program the C8051F060 MCU from keil IDE with Silabs JTAG adapter (which you have mentioned).
How to Connect the JTAG adapter?
From where i can buy the JTAG adapter?
From SiLabs! (or your local distributor)
"How to Connect the JTAG adapter?"
Follow the instructions when you get it?
"Can I directly program the C8051F060 MCU from keil IDE with Silabs JTAG adapter (which you have mentioned)."
Yes.
