which gnu-tool-prefix do I have to use in order to work with Sourcery and arm-none-linux-gnueabi?
arm-none-linux-gnueabi or arm-none-linux isn't working... getting the error msg "failed to execute"...
best regards Hannes
Look at the file names in the 'bin' directory where you installed the compiler.
See: http://www.keil.com/forum/docs/thread12738.asp
Thanks for the hint but unfortunately it doesn't work. It seems that maybe the name is too long??
[bin directory] arm-none-linux-gnueabi-gcc.exe
thanks Andy for the sample-project: I use the same prefix as in that example-project.
Do I have to do any updates in the path-variable?? Including also the folder where Keil is located??
the error msg is
Error: failed to execute 'arm-none-linux-gnueabiarm-none-linux-gnueabiarm-none-linux-gnueabi-ar'
So it seems that there's a difference: if I use another (false) prefix, the error msg is only failed to execute 'arm-linux-gcc' or whatever... but not so long
gnu-tool prefix: arm-none-linux-gnueabi-
