could any provide me with the Keil c library files serial.h lcdrout.h
Is there a reason why you think these files are part of the Keil C library? And is there a reason why you think that you haven't received them, while other people have?
did you download the latest MDK and had a look at the examples?
If the files are "free" (for use with uVision) they can be found in the examples.
BR, /th.
He said very right. There are a lot of examples in the MDK folders. You can find the source files and header files in the "board folders". D:\Program Files\Keil\ARM\Boards\Atmel\AT91SAM7S-EK\Hello the serial.c file in this folder. The serial.h just like below: #ifndef __SERIAL_H__ #define __SERIAL_H__
/* add the serial function */ void init_serial (void); ....
/* you copy the first line of every small programs from the source file to header file */
#endif /* __SERIAL_H__ */
for your reference only
Note that the OP didn't even state a toolset - let alone a specific board from a specific manufacturer!
Therefore there is very little reason to beleive that this is the actual "serial.h" file that he enquired about!
A quick search of my Keil install folder shows at least three other files also called "serial.h"
This really goes to show how pointless it is to just ask for a filename like "serial.h" with no other details!!
And it doesn't seem that the OP is really interested anyhow!
