Hello forum, I want to take use of precompiled header files in my project. My project is split into two parts. A library part and an application part.
The application part is using the library part by including a single header file called library.hpp. library.hpp contains a ton of includes.
I want to create a pch file out of library.hpp and force the ARM compiler to use that instead of recompiling each header file over and over again. My problem is that I don't get uVision3 configured in a way that this pch file is properly created.
Here is what I did so far: - create a cpp file called library.cpp - configured the library.cpp C/C++ options with --create_pch=library.pch - configured the overall project C/C++ options with --use_pch=library.pch
When I compile the project the library.pch is created but for each cpp file that is processed the compiler outputs a warning that the pch file has been created with compiler options different from current options.
Please can you give me a hint what I am doing wrong or direct me to any tutorials, sample projects? I am using Cortex-M3 on ARM-MDK4.0 with uVision 3.9 Thanks a lot in advance and best regards Jan
Turn on listing files, so you get *.txt files in the output directory. At the top of each *.txt file, you will see a list of compiler options used for compiling that source file.
Is there any difference between compiling the source files in the library and the source files using the library?
@cc: Thanks for your quick response I will try that as soon as I am back in the office today!
Hi Per, I tried to get a clue out of the list files but can't say there are differences.
Actually I think that I do something wrong when creating the pch file.
How would you configure a project for using pch files?
Thanks a lot in advance and best regards. Jan
Hi again, here's a short update of what I did so far:
I have three files: main.cpp stdafx.cpp stdafx.hpp
In C/C++ options I added a "Misc Control" to main.cpp: --use_pch=stdafx.pch
In C/C++ options I added a "Misc Control" to stdafx.cpp: --create_pch=stdafx.pch
my main.cpp looks like this:
#include "stdafx.hpp" int main(void) { }
my stdafx.cpp looks like this: #include "stdafx.hpp"
my stdafx.hpp looks like this: #include "..." #include "..." // ... tons of includes
When I build my mini project I am getting the following warning: main.cpp: Warning: #629-D: the command line options do not match those used when precompiled header file "stdafx.pch" was created
I really don't know how to get this pch thing working with Keil!
Please can anyone help me and direct me how to set these things up correctly? Thanks a lot in advance! Jan
