to transfer more bytes from kit to pc
i want to transfer to/from 64 bytes from kit to pc and viceversa.so i made the following changes in the code.
in HID_Client VC++ program in HIDClientDlg.cpp
the if conidtion on !HID_WRITE(); is becomes false and
executing OnError();
so herewith i'd attached the program modification. Please can anyone tell me what mistake i made or what correction/modification i need to carry.
in the USBTrace the buffer shows the value sent from kit to PC. So i think the transfer from kit to pc is ok. it is problem with receiving from pc. or problem with Device descriptor.
with regards
S.Venugopal
void CHIDClientDlg::OnSelchangeDevice()
  DWORD cnt;
  int   n;
      if (!HID_Write(OutReport, sizeof(OutReport), &cnt)) {
        OnError();
        return;
// in usbdesc.c
/* HID Report Descriptor */
const BYTE HID_ReportDescriptor[] = {
  HID_UsagePageVendor(0x00),
  HID_Usage(0x01),
  HID_Collection(HID_Application),
    HID_UsagePage(HID_USAGE_PAGE_GENERIC),
    HID_UsageMin(0),
    HID_UsageMax(255),
    HID_LogicalMin(0),
    HID_LogicalMaxS(255),
    HID_ReportCount(64),
    HID_ReportSize(8),
    HID_Input(HID_Data | HID_Variable | HID_Absolute),
    HID_Usage(HID_USAGE_GENERIC_UNDEFINED),
    HID_LogicalMin(0),
    HID_ReportSize(8),
    HID_Output(HID_Data | HID_Variable | HID_Absolute),
  HID_EndCollection,
 const WORD HID_ReportDescSize = sizeof(HID_ReportDescriptor);
const BYTE USB_ConfigDescriptor[] = {
//WBVAL(0x0004),                     /* wMaxPacketSize -- 4*/
  WBVAL(0x0040),                     /* wMaxPacketSize -- 64*/
//  0x20,          /* 32ms */          /* bInterval */
  0xFA,          /* 250ms */          /* bInterval */
/* Terminator */
  0                                  /* bLength */
// in demo.c
BYTE InReport[USB_MAX_PACKET0];
BYTE OutReport[USB_MAX_PACKET0];
void GetInReport (void) {
        unsigned char i;
 for (i=0; i<=64; i++)
        InReport[i] = i;
void SetOutReport (void) {
  GPIOB->ODR = (OutReport[0] << 8);                     // All LED Bits are set
// in demo.h
extern BYTE   InReport[USB_MAX_PACKET0];
extern BYTE   OutReport[USB_MAX_PACKET0];
//inc usbcfg.h
//#define USB_MAX_PACKET0     8
#define USB_MAX_PACKET0     64
// in usbuser.c
#if USB_CONFIGURE_EVENT
void USB_Configure_Event (void) {
  if (USB_Configuration) {                  /* Check if USB is configured */
    GetInReport();
    USB_WriteEP(0x81, &InReport[0], sizeof(InReport));
#endif
void USB_EndPoint1 (DWORD event) {
  GetInReport();
BOOL HID_GetReport (void) {
unsigned char i;
  /* ReportID = SetupPacket.wValue.WB.L; */
  switch (SetupPacket.wValue.WB.H) {
    case HID_REPORT_INPUT:
    GetInReport();
          for(i=0; i<=64; i++) {
          EP0Buf[i] = InReport[i];
          break;
    case HID_REPORT_OUTPUT:
      return (FALSE);          /* Not Supported */
    case HID_REPORT_FEATURE:
      /* EP0Buf[] = ...; */
      /* break; */
  return (TRUE);
BOOL HID_SetReport (void) {
      OutReport[0] = EP0Buf[0];
      SetOutReport();
      break;
  return (TRUE);
