Hello...first, sorry for the bad suuamry, i cannot change it, i hope you are understand what i mean. i'm doing some project with lots of float data type. now i need to convert the result of calculation(which is a float data type) to longword so i can use the DIV(/) or MOD(%) in C. anyone can help me?
MCU = ASEM51 @20MHz
best regards
Aldi
Are you aware that C has the concept of type conversion?
void func(void) { float f; long l; f = 123.456f; l = (long)f; /* explicit conversion */ l = f; /* implicit conversion */ l %= 10; }
you are very thanked for my reply but you did not say it does work at 20MHz. all my sample must be good for it or it will not work!
How would the clock frequency affect the standard behaviour of the 'C' programming language??!!
If the processor is too slow for the task, then the fault is on you for having selected the wrong processor.
By the way - why did you select generic if your problem isn't generic?
