LPC2103 PWM problem
I have a problem with PWM on LPC2103 P0.7 connected to MAT2.0. PWM signal although works fine on P0.8 connected to MAT2.1. I'm using Keil 4.12 eval.
If I use WinARM (GNU GCC) everything works fine (PWM on both ports - P0.7 or P0.8). Here is the sample code tested on MCB2103 and simulator with logic analyzer.
If anyone has some idea I'd be thankful :)
#include <LPC2103.H>
int main(void)
 PINSEL0 |= 0x00028000;
 T2TCR = 1<<1; // Reset TC and PC, disable timer
 T2PR = 0;     // Prescaling
 T2TC = 0;
 T2MCR = 0x0400;           // Reset on MR3 match
 T2PWMCON = 0x0000000b;    // Enable PWMs
 T2EMR  = 0x3<<4 | 0x3<<6; // Enable MAT2.0, MAT2.1 and set toggle mode
 // Setup PWM parameters
 T2MR3 = 255; // Period duration
 T2MR1 = 127; // Pulse width
 T2MR0 = 127; // Pulse width
 T2TCR = 1<<0; // Enable counter
 while(1);
