I'm trying to use inline assembler code but the keyword '__asm' is not accepted. I can create an '__asm' function with no compiler warnings but when calling this function the uC restarts. Using Cortex M3 device.
Regards,
Henk
Use only this format - called embedded assembly:
__asm void delay(int32u a_microseconds) { loop SUB R0, R0, #1 CMP R0, #0 BNE loop BX LR }
Forget about inline assembly altogether! See your manuals for details about the differences.
