Dear all,
I took two MCB2300 keil boards, loaded them with nichelite's TCP stack (keil ported version Downloaded from NXP site), and after that,
set IPs to both them 199.199.50.66 and 199.199.50.67 respectively. (as 199.199.50.x is my NW pattern)
[Off course Plug them in to office network].
I observe that at a time any of the a board can communicate in office LAN ( other get down) , via PING ( I checked PING from other PCs).
And I see that any a board can communicate with N number of PCs but , when I plug 2 boards in network then any one only can communicate !!
Is there any setting(s) I am missing that i should make in any of header/config file of stack code?
[I checked IP values not conflicting, and I am setting IP by what user commands they given like setip etc, in non DHCP mode]
Pls help me, if anybody have exp. with nichelite.
I haven't played with this combination, but where do your two boards gets their MAC addresses from? Every device in the network must have a unique MAC address, sinc ehte TCP/IP data is really addressed to a MAC address. The IP address is just used to ask the board what MAC address it has, before doing the real communication.
Thanks buddy,
I get this work by MAC change.
Now what issue I am facing is for PING (Network) connectivity.
My Office network have around 80 PCs in LAN, When I am configuring Nichelite loaded board with IP 199.199.50.67 (unique ip), and plug it in network.
Here I am doing PING test with any of the networked PC. It works well initially.
But, After some time (say 1/2/3 hours) pc is not getting reply of the PING.
At that time I debugged at code. What I see is that eth_isr0(void) __irq (emac.c) is not getting invoke (which should- I think) anymore then.
I referred the implementation manual published at NXP site for nichelite implementation note.
From which I could tried to alter NUMBIGBUFS,NUMLILBUFS,BIGBUFSIZE,LILBUFSIZE defines by diff values , I could see that it affects how much time the board can live in network.
Is there any rugged method/patch which i can apply to make sure my MCB2300 board lives in the network 24x7 with (continuous PING TEST form other PC)
I will appreciate any help, -Saurabh
Additional info:
I observe it every time after it dropped the PING connection, remaining OS contine to work, I can enter debug commands.
And on givinh the buffer command, it shows all allocated buffers , at there it shows many duplicate buffers already allocated (bigbufs).
I see each time that 5-7 duplicate bigbufs allocated (may be they have not been de-allocated may cause of communication failure)
