I'have a problem with uVision. When I open a project I expect to see my project window and a output window.
Suddenly when I open a project, the output window isn't visible any more. When I click View->output window, it is still enabled but not visible/movable.
Can someone help me with this?!
IDE-Version: µVision3 V3.90 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009
OS: Windows XP Pro Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 3.80a Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.0.0.524 Assembler: Armasm.Exe V4.0.0.524 Linker/Locator: ArmLink.Exe V4.0.0.524 Librarian: ArmAr.Exe V4.0.0.524 Hex Converter: FromElf.Exe V4.0.0.524 CPU DLL: SARM.DLL V3.80a Dialog DLL: DARMP.DLL V1.46 Target DLL: BIN\UL2ARM.DLL V1.50 Dialog DLL: TARMP.DLL V1.46
I have the exact same situation. One time when I deleted all otp and bak files the window came back. But now its gone forever!
Keil, help us
IDE-Version: µVision3 V3.80 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009
License Information: Fredrik Einberg Cypak Ab LIC=ZBDXI-T85PK-CBUEI-R4UUZ-CZLPV-2AW1P
Tool Version Numbers: Toolchain: PK51 Prof. Developers Kit Version: 8.18 Toolchain Path: C:\Program Files\Keil\C51\BIN\ C Compiler: C51.Exe V8.18 Assembler: AX51.Exe V3.06h Linker/Locator: LX51.Exe V4.39 Librarian: LIBX51.Exe V4.24 Hex Converter: OHX51.Exe V1.36e CPU DLL: S8051.DLL V3.65 Dialog DLL: DCore51.DLL V2.68 Target DLL: C:\PROGRA~1\Fs2\SysNav\Bin\fs2keil51.dll Dialog DLL: TCore51.DLL V2.63
See this:
http://www.keil.com/support/docs/2928.htm
